メインコンテンツにスキップ
Sony Vaio SVE111B11L Screen Replacement
必要な工具と部品
  1. Sony Vaio SVE111B11L  Screen Replacement, Battery: 手順 1、 2の画像 1 Sony Vaio SVE111B11L  Screen Replacement, Battery: 手順 1、 2の画像 2
    • Remove the charging adaptor. Some charge may still be in the battery or computer. DO NOT touch connectors or copper yellow connector.
    • Locate the battery on the bottom of the computer.
    • Flip the computer so that the battery faces you.
  2. Sony Vaio SVE111B11L  Screen Replacement: 手順 2、 1の画像 1
    • Locate the two latches with the words “lock” and “release” on them.
  3. Sony Vaio SVE111B11L  Screen Replacement: 手順 3、 1の画像 1
    • Push the latches towards each other and lift the battery to remove it.
  4. Sony Vaio SVE111B11L  Screen Replacement, Keyboard Assembly: 手順 4、 1の画像 1
    • Remove the memory door on the bottom of the computer to access the screw for the keyboard.
    • The screws for the memory door do not come out.
  5. Sony Vaio SVE111B11L  Screen Replacement: 手順 5、 1の画像 1
    • Remove the 6.7 mm screw that holds the keyboard assembly in place.
  6. Sony Vaio SVE111B11L  Screen Replacement: 手順 6、 1の画像 1
    • Be careful not to break the keyboard wire connection.
    • Slide the wires out, away from the solder connections.
    • Flip the computer over and open it.
  7. Sony Vaio SVE111B11L  Screen Replacement: 手順 7、 3の画像 1 Sony Vaio SVE111B11L  Screen Replacement: 手順 7、 3の画像 2 Sony Vaio SVE111B11L  Screen Replacement: 手順 7、 3の画像 3
    • Gently pry the keyboard assembly from the screen side, using an opening tool. You will need to lift the keyboard about two inches.
    • Using an opening tool, gently pull out and slightly up on the connector clip.
    • Gently lift the keyboard assembly up and out.
  8. Sony Vaio SVE111B11L  Screen Replacement, Motherboard: 手順 8、 1の画像 1
    • Remove charging adaptor. Some charge may still be in the battery or computer.
    • DO NOT touch connectors or copper yellow connector.
    • Take the covers on the bottom of the laptop off.
  9. Sony Vaio SVE111B11L  Screen Replacement: 手順 9、 1の画像 1
    • Locate and remove the screws holding the motherboard down.
    • Screws: L 4.6mm X D 1.85mm
  10. Sony Vaio SVE111B11L  Screen Replacement: 手順 10、 3の画像 1 Sony Vaio SVE111B11L  Screen Replacement: 手順 10、 3の画像 2 Sony Vaio SVE111B11L  Screen Replacement: 手順 10、 3の画像 3
    • Locate the wires and connectors and remove them from the motherboard.
  11. Sony Vaio SVE111B11L  Screen Replacement: 手順 11、 2の画像 1 Sony Vaio SVE111B11L  Screen Replacement: 手順 11、 2の画像 2
    • Lift the mother board out and safely put it to the side.
  12. Sony Vaio SVE111B11L  Screen Replacement, Screen: 手順 12、 2の画像 1 Sony Vaio SVE111B11L  Screen Replacement, Screen: 手順 12、 2の画像 2
    • Remove charging adaptor and battery. Some charge may still be in the battery or computer.
    • Locate screws. L 3.35mm X D 1.8mm
    • Remove Screws.
    • Lay the screen on a hard flat surface.
    • Remove hinges and wires for ease of removal.
  13. Sony Vaio SVE111B11L  Screen Replacement: 手順 13、 1の画像 1
    • Gently remove the screen cover.
    • Be careful of the camera at the top of the screen.
    • Be careful of the seal tape between the cover and the screen.
  14. Sony Vaio SVE111B11L  Screen Replacement: 手順 14、 3の画像 1 Sony Vaio SVE111B11L  Screen Replacement: 手順 14、 3の画像 2 Sony Vaio SVE111B11L  Screen Replacement: 手順 14、 3の画像 3
    • Locate the wires and connectors.
    • Unplug the wires from the connectors.
    • Be careful of the yellow tape around the connection.
  15. Sony Vaio SVE111B11L  Screen Replacement: 手順 15、 2の画像 1 Sony Vaio SVE111B11L  Screen Replacement: 手順 15、 2の画像 2
    • Gently lift the screen assembly up and out.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
John Noll
メンバー登録日: 09/29/16
819 ポイント
5のガイドは作成済み
チーム
Eastern Washington University, Team 1-5, Crane Fall 2016 Eastern Washington University, Team 1-5, Crane Fall 2016人のメンバー
EWU-CRANE-F16S1G5
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 9
今までの合計 1,226
