はじめに
If the display is damaged and does not function properly, you should remove it and get it repaired or replaced.
CAUTION: Static electricity in your body can ruin you computer. Use an anti-static wristband.
必要な工具と部品
The battery is located on the left side of the laptop, as shown by the red circle.
Make sure the laptop is disconnected and turned completely off.
Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
Use tweezers to remove the rubber covers on the four screws at the corners near the display.
Locate the ribbon cable slot and the two-pin backlight cable. These are essential connections for the display.
Gently, but firmly, grasp the ribbon cable near its connection point.
Use steady, even pressure to pull the ribbon cable out of its socket. Be careful not to use excessive force.
Similarly, disconnect the two-pin backlight cable with gentle and controlled force. Ensure you disconnect both cables securely to avoid any damage during removal.
