メインコンテンツにスキップ
Sony Vaio PCG-F420 CD/DVD Drive Replacement
必要な工具と部品
  1. Sony Vaio PCG-F420 CD/DVD Drive Replacement, Battery: 手順 1、 1の画像 1
    • The battery is located on the left side of the laptop, as shown by the red circle.
    • Make sure the laptop is disconnected and turned completely off.
  2. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 2、 1の画像 1
    • Remove the battery by following these steps.
    • Pull the plastic cover down (indicated by the arrow on the cover) and then swing it upwards to reveal the battery compartment.
    • The battery can now be removed by pulling it.
  3. Sony Vaio PCG-F420 CD/DVD Drive Replacement, Keyboard: 手順 3、 1の画像 1
    • Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
  4. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 4、 1の画像 1
    • Unlock the cover between the keyboard and screen.
    • Gently slide it to the right and lift it up.
    • Exercise caution to avoid excessive force, as wires are connected.
    • Be mindful not to pull the keyboard too forcefully as it remains connected to wires, which we will address in the next step.
  5. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 5、 1の画像 1
    • Lift up the cover and lean it against the display so it is out of the way for the rest of the process.
    • Remove the small screw above the F6 key on the keyboard. Place screw in container to ensure it wont be lost.
  6. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 6、 1の画像 1
    • Find the green ribbon as indicated in the picture by the red circle. This is what connects the keyboard to the motherboard.
  7. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 7、 1の画像 1
    • Carefully unplug the ribbon cable using a pair of tweezers.
    • Lift up the white bar near the connection to the motherboard, and lightly lift the ribbon to release it from the motherboard.
  8. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 8、 2の画像 1 Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 8、 2の画像 2
    • Now, pull on the ribbon cable, and it will detach from the motherboard.
    • Your keyboard is now safely detached, allowing for necessary repairs or replacements.
  9. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 9、 1の画像 1
    • Your keyboard is now safety detached. Necessary repairs or replacements can be made from here.
  10. Sony Vaio PCG-F420 CD/DVD Drive Replacement, CD/DVD Drive: 手順 10、 1の画像 1
    • After removing the keyboard, unscrew (using Phillips #00) the circled screw securing the CD/DVD drive.
  11. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 11、 1の画像 1
    • After unscrewing the CD/DVD drive, gently slide the drive slightly out of the main computer case, as shown. Be careful not to rip off the harness.
  12. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 12、 1の画像 1
    • Carefully detach the harness from the CD/DVD drive. Use your fingers if possible, but if not carefully use a pair of tweezers to detach the harness. Take care in not bending any of the pin connections.
  13. Sony Vaio PCG-F420 CD/DVD Drive Replacement: 手順 13、 1の画像 1
    • After disconnecting the harness you can now slide the CD/DVD drive fully out of the computer. You can now repair or replace your CD/DVD drive.
終わりに
作成者
7人の作成者と共同で作成されました。
Andrew Quayle
メンバー登録日: 04/15/10
44 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 29-77, Johann Spring 2010 Cal Poly, Team 29-77, Johann Spring 2010人のメンバー
CPSU-JOHANN-S10S29G77
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 4,026
