はじめに
Replacing the CD/DVD drive involves first removing the keyboard, then a screw will free it from the frame. Then, simply unplug the ribbon cable and pull it out.
CAUTION: Static electricity in your body can ruin you computer. Use an anti-static wristband.
必要な工具と部品
The battery is located on the left side of the laptop, as shown by the red circle.
Make sure the laptop is disconnected and turned completely off.
Use your Philips #00 screwdriver to unscrew the small screw counterclockwise. This screw is for the audio/visual jacks on the left side of the laptop.
After removing the keyboard, unscrew (using Phillips #00) the circled screw securing the CD/DVD drive.
