メインコンテンツにスキップ
Sony Vaio PCG-F360 Optical Drive Replacement
必要な工具と部品
  1. Sony Vaio PCG-F360 Optical Drive Replacement, Battery: 手順 1、 1の画像 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony Vaio PCG-F360 Optical Drive Replacement: 手順 2、 1の画像 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony Vaio PCG-F360 Optical Drive Replacement: 手順 3、 1の画像 1
    • Use the indentations to pull the old battery out.
  4. Sony Vaio PCG-F360 Optical Drive Replacement: 手順 4、 1の画像 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: 手順 5、 3の画像 1 Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: 手順 5、 3の画像 2 Sony Vaio PCG-F360 Optical Drive Replacement, Keyboard: 手順 5、 3の画像 3
    • There are two screws on the left hand side of the laptop near the IR (Infared remote) receiver (see image). Remove them using a Phillips #00 Screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony Vaio PCG-F360 Optical Drive Replacement: 手順 6、 3の画像 1 Sony Vaio PCG-F360 Optical Drive Replacement: 手順 6、 3の画像 2 Sony Vaio PCG-F360 Optical Drive Replacement: 手順 6、 3の画像 3
    • On the inside of the speaker panel, using a spudger, push the beige tab in the direction of the ribbon. It should only move a small amount.
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony Vaio PCG-F360 Optical Drive Replacement: 手順 7、 2の画像 1 Sony Vaio PCG-F360 Optical Drive Replacement: 手順 7、 2の画像 2
    • Remove the metal screw that will be located at the red circle.
    • Pull on the green strip, and the keyboard should come free easily.
  8. Sony Vaio PCG-F360 Optical Drive Replacement, Optical Drive: 手順 8、 2の画像 1 Sony Vaio PCG-F360 Optical Drive Replacement, Optical Drive: 手順 8、 2の画像 2
    • Remove the three screws surrounding the fan.
    • Take off the guard that you just unscrewed.
    • Carefully flip over the heat pipe and the metal sheet connected to it.
  9. Sony Vaio PCG-F360 Optical Drive Replacement: 手順 9、 3の画像 1 Sony Vaio PCG-F360 Optical Drive Replacement: 手順 9、 3の画像 2 Sony Vaio PCG-F360 Optical Drive Replacement: 手順 9、 3の画像 3
    • Remove the three screws from the heat tube cover.
    • Carefully remove the cover.
  10. Sony Vaio PCG-F360 Optical Drive Replacement: 手順 10、 2の画像 1 Sony Vaio PCG-F360 Optical Drive Replacement: 手順 10、 2の画像 2
    • Use a spudger to pry the ribbon connected to the optical drive.
    • Slide the optical drive free of the enclosure.
終わりに
作成者
9人の作成者と共同で作成されました。
ahintz
メンバー登録日: 04/21/10
28 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 16-3, Maness Spring 2010 Cal Poly, Team 16-3, Maness Spring 2010人のメンバー
CPSU-MANESS-S10S16G3
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 2
今までの合計 1,770
