この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If for any reason the floppy drive isn't working, the simplest solution is to replace the entire drive. But, if you're not able to acquire a new drive you may be able at least find the source of the failure through disassembling the drive.
必要な工具と部品
Turn the device over so that its underside is facing up. Then, slide the blue floppy drive release button down and pull the floppy drive out of the laptop.
もう少しです!
終わりに
