この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide show you how to remove the back cover to access the CD-ROM drive, the cooling fan, and other parts in order to remove the keyboard and screen.
必要な工具と部品
With the bottom of the laptop facing up, locate the RAM cover.
The RAM is covered by the panel with four columns of vents.
Locate the screw (Length: 4.8 mm) holding down the panel, which is near the edge of the laptop. Unscrew it with your phillips #0 screwdriver.
Locate and remove the screw (Length: 7.7mm) for the hard drive cover.
Slide the cover until it is free from the laptop case.
Lift the cover to remove.
Locate the screws highlighted here. There are 16 total.
Using a Phillips #0 screwdriver, remove the screws (Length: 6.8mm) and place them on a tray for later use.
4 の人々がこのガイドを完成させました。
