メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
Installing or replacing a hard drive is a fairly simple procedure. It only involves a total of 6 screws and up to a 320 GB HDD.
  1. First, locate the hard drive slot on the under side of the laptop. Unscrew the screws using your Phillips #00 screwdriver. Set the two screws aside so you can screw them in later on when you're finished.
    • First, locate the hard drive slot on the under side of the laptop.
    • Unscrew the screws using your Phillips #00 screwdriver.
    • Set the two screws aside so you can screw them in later on when you're finished.
    • This should reveal a small metallic place holder that your hard drive belongs.
  2. Unscrew the 4 hard drive bracket screws. Once the screw is undone you can pull the place holder back to find the  slot where the actual hard drive belongs.
    • Unscrew the 4 hard drive bracket screws.
    • Once the screw is undone you can pull the place holder back to find the slot where the actual hard drive belongs.
    • Remember to set aside the screw so you can correctly install the hard drive.
終わりに
The installation/replacement is a very easy task that can be done by anyone.
Alberto Rosas
メンバー登録日: 2018年09月21日
149 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team S2-G7, Riccardelli Fall 2018 University of North Texas, Team S2-G7, Riccardelli Fall 2018人のメンバー
UNT-RICCARDELLI-F18S2G7
5 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 278
