この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to assist you in replacing your laptop's optical drive.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged and turned off before performing any maintenance on the system.
必要な工具と部品
Set the computer display-side down.
Unlock the battery by sliding the port-side latch to the 'unlock' position.
Turn the laptop upside down.
Remove the three screws from the front mouse panel located on the bottom of the laptop.
5 の人々がこのガイドを完成させました。
