はじめに
The optical disc drive allows your laptop to read and play discs. This is a guide to help you replace the component if you encounter functionality issues.
必要な工具と部品
Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
Remove the 5mm screws with the PH0 screwdriver.
Remove the 3mm screws with the PH0 screwdriver.
もう少しです!
終わりに
