メインコンテンツにスキップ
Sony Vaio PCG-61411L Keyboard Replacement
アーカイブされたガイド
このガイドは将来的な使用のためにのみ保存されてます。ご自身の修理作業には更新バージョンをご利用ください。
必要な工具と部品
  1. Sony Vaio PCG-61411L Keyboard Replacement, Battery: 手順 1、 3の画像 1 Sony Vaio PCG-61411L Keyboard Replacement, Battery: 手順 1、 3の画像 2 Sony Vaio PCG-61411L Keyboard Replacement, Battery: 手順 1、 3の画像 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Keyboard Replacement: 手順 2、 3の画像 1 Sony Vaio PCG-61411L Keyboard Replacement: 手順 2、 3の画像 2 Sony Vaio PCG-61411L Keyboard Replacement: 手順 2、 3の画像 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Keyboard Replacement, Hard Drive: 手順 3、 1の画像 1
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Keyboard Replacement: 手順 4、 2の画像 1 Sony Vaio PCG-61411L Keyboard Replacement: 手順 4、 2の画像 2
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Keyboard Replacement: 手順 5、 3の画像 1 Sony Vaio PCG-61411L Keyboard Replacement: 手順 5、 3の画像 2 Sony Vaio PCG-61411L Keyboard Replacement: 手順 5、 3の画像 3
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Keyboard Replacement: 手順 6、 3の画像 1 Sony Vaio PCG-61411L Keyboard Replacement: 手順 6、 3の画像 2 Sony Vaio PCG-61411L Keyboard Replacement: 手順 6、 3の画像 3
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
  7. Sony Vaio PCG-61411L Keyboard Replacement, Optical Disc Drive: 手順 7、 2の画像 1 Sony Vaio PCG-61411L Keyboard Replacement, Optical Disc Drive: 手順 7、 2の画像 2
    • Remove the 5mm screws with the PH0 screwdriver.
    • Remove the 3mm screws with the PH0 screwdriver.
  8. Sony Vaio PCG-61411L Keyboard Replacement: 手順 8、 2の画像 1 Sony Vaio PCG-61411L Keyboard Replacement: 手順 8、 2の画像 2
    • Lift the backplate from bottom right and left corner and remove it from the laptop.
  9. Sony Vaio PCG-61411L Keyboard Replacement: 手順 9、 2の画像 1 Sony Vaio PCG-61411L Keyboard Replacement: 手順 9、 2の画像 2
    • Slide your finger from the right of the optical disc and pull the optical disc from right to left.
  10. Sony Vaio PCG-61411L Keyboard Replacement, Keyboard: 手順 10、 2の画像 1 Sony Vaio PCG-61411L Keyboard Replacement, Keyboard: 手順 10、 2の画像 2
    • Push keyboard out from the hole located in the optical drives original location.
  11. Sony Vaio PCG-61411L Keyboard Replacement: 手順 11、 3の画像 1 Sony Vaio PCG-61411L Keyboard Replacement: 手順 11、 3の画像 2 Sony Vaio PCG-61411L Keyboard Replacement: 手順 11、 3の画像 3
    • Remove the keyboard cover by gently pulling along the sides until it is removed completely.
  12. Sony Vaio PCG-61411L Keyboard Replacement: 手順 12、 2の画像 1 Sony Vaio PCG-61411L Keyboard Replacement: 手順 12、 2の画像 2
    • Disconnect the keyboard by pulling the connection wire in the opposite direction of where it's connected.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Patrick Jean Baptiste
メンバー登録日: 03/01/18
214 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 UMass Dartmouth, Team S2-G1, Simcock Spring 2018人のメンバー
UMASSD-SIMCOCK-S18S2G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,387
