メインコンテンツにスキップ
Sony Vaio PCG-61411L Hard Drive Replacement
必要な工具と部品
  1. Sony Vaio PCG-61411L Hard Drive Replacement, Battery: 手順 1、 3の画像 1 Sony Vaio PCG-61411L Hard Drive Replacement, Battery: 手順 1、 3の画像 2 Sony Vaio PCG-61411L Hard Drive Replacement, Battery: 手順 1、 3の画像 3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio PCG-61411L Hard Drive Replacement: 手順 2、 3の画像 1 Sony Vaio PCG-61411L Hard Drive Replacement: 手順 2、 3の画像 2 Sony Vaio PCG-61411L Hard Drive Replacement: 手順 2、 3の画像 3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio PCG-61411L Hard Drive Replacement, Hard Drive: 手順 3、 1の画像 1
    • The hard drive panel is located in the bottom right corner of the device.
  4. Sony Vaio PCG-61411L Hard Drive Replacement: 手順 4、 2の画像 1 Sony Vaio PCG-61411L Hard Drive Replacement: 手順 4、 2の画像 2
    • Using the PH #0 screwdriver, unscrew the two 6.5mm screws located in the bottom left and middle right of the panel. The screws remain in the panels.
    • Remove the panel by pulling it up towards yourself.
  5. Sony Vaio PCG-61411L Hard Drive Replacement: 手順 5、 3の画像 1 Sony Vaio PCG-61411L Hard Drive Replacement: 手順 5、 3の画像 2 Sony Vaio PCG-61411L Hard Drive Replacement: 手順 5、 3の画像 3
    • Using a PH0 screwdriver, remove the four 3mm silver screws located in the external hard drive cover.
    • Using a PH00 screwdriver, remove the final 3mm black screw located in the top right section of the hard drive cover.
    • Carefully remove the silver hard drive cover.
  6. Sony Vaio PCG-61411L Hard Drive Replacement: 手順 6、 3の画像 1 Sony Vaio PCG-61411L Hard Drive Replacement: 手順 6、 3の画像 2 Sony Vaio PCG-61411L Hard Drive Replacement: 手順 6、 3の画像 3
    • Detach the hard drive by disconnecting it from the motherboard, pulling it gently from left to right.
終わりに
ある他の人がこのガイドを完成しました。
作成者
1人の作成者と共同作成されました。
Sean Lyon
メンバー登録日: 03/01/18
381 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team S2-G1, Simcock Spring 2018 UMass Dartmouth, Team S2-G1, Simcock Spring 2018人のメンバー
UMASSD-SIMCOCK-S18S2G1
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 34
今までの合計 1,618
