メインコンテンツにスキップ
Sony Vaio VGN-SR140E Screen Replacement
必要な工具と部品
  1. Sony Vaio VGN-SR140E Screen Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Screen Replacement: 手順 2、 1の画像 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Screen Replacement: 手順 3、 2の画像 1 Sony Vaio VGN-SR140E Screen Replacement: 手順 3、 2の画像 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Screen Replacement, Screen: 手順 4、 3の画像 1 Sony Vaio VGN-SR140E Screen Replacement, Screen: 手順 4、 3の画像 2 Sony Vaio VGN-SR140E Screen Replacement, Screen: 手順 4、 3の画像 3
    • Remove the rubber pads at all four corners of the screen bezel using a spudger. This will reveal four 5mm Phillips screws.
    • Use a Phillips #1 screwdriver to remove the four screws and set them aside.
  5. Sony Vaio VGN-SR140E Screen Replacement: 手順 5、 1の画像 1
    • Remove the screen's plastic bezel. You may need to use slight pressure to release the clips that secure the bezel to the laptop.
  6. Sony Vaio VGN-SR140E Screen Replacement: 手順 6、 2の画像 1 Sony Vaio VGN-SR140E Screen Replacement: 手順 6、 2の画像 2
    • Lift screen bezel up and off of the laptop.
  7. Sony Vaio VGN-SR140E Screen Replacement: 手順 7、 3の画像 1 Sony Vaio VGN-SR140E Screen Replacement: 手順 7、 3の画像 2 Sony Vaio VGN-SR140E Screen Replacement: 手順 7、 3の画像 3
    • Close the laptop carefully and slowly while holding the screen with your thumb to prevent it from falling.
    • Lay the screen gently on the keyboard. This will reveal the screen's connector.
  8. Sony Vaio VGN-SR140E Screen Replacement: 手順 8、 3の画像 1 Sony Vaio VGN-SR140E Screen Replacement: 手順 8、 3の画像 2 Sony Vaio VGN-SR140E Screen Replacement: 手順 8、 3の画像 3
    • Grasp the connector and gently pull it out.
  9. Sony Vaio VGN-SR140E Screen Replacement: 手順 9、 1の画像 1
    • The screen can now be removed.
終わりに
作成者
3人の作成者と共同で作成されました。
Jeremy
メンバー登録日: 03/18/15
722 ポイント
4のガイドは作成済み
チーム
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G6
2 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 11
今までの合計 1,120
