メインコンテンツにスキップ
はじめに
The battery needs to removed before servicing or replacing any other component. The RAM is under a panel held on by two screws. The RAM is easy to remove once the panel is off.
パーツ
パーツは指定されていません。
  1. Turn the laptop over and orient it as shown in the figure.
    • Turn the laptop over and orient it as shown in the figure.
  2. Slide the lock latch to the right to release the battery lock.
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop. Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
    • Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
  5. Lift the thin black plastic cover to access the RAM. Lift the thin black plastic cover to access the RAM.
    • Lift the thin black plastic cover to access the RAM.
  6. Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it. Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it.
    • Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it.
  7. Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot. Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot. Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot.
    • Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot.
終わりに
Jeremy
メンバー登録日: 2015年03月18日
694 ポイント
4のガイドは作成済み
チーム
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G6
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 308
