メインコンテンツにスキップ
Sony Vaio VGN-SR140E Hard Drive Replacement
必要な工具と部品
  1. Sony Vaio VGN-SR140E Hard Drive Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Hard Drive Replacement: 手順 2、 1の画像 1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Hard Drive Replacement: 手順 3、 2の画像 1 Sony Vaio VGN-SR140E Hard Drive Replacement: 手順 3、 2の画像 2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Hard Drive Replacement, Hard Drive: 手順 4、 1の画像 1
    • Using a Phillips #1 screw driver, loosen both screws holding the cover in place. These screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E Hard Drive Replacement: 手順 5、 1の画像 1
    • Lift the cover with a fingernail or plastic opening tool from the side where the screws are present and lift it off to the left.
  6. Sony Vaio VGN-SR140E Hard Drive Replacement: 手順 6、 1の画像 1
    • The hard drive is covered by a thin, black, plastic flap. Gently lift the hard drive up and to the right.
    • Be careful not to damage the ribbon cable during this step.
  7. Sony Vaio VGN-SR140E Hard Drive Replacement: 手順 7、 2の画像 1 Sony Vaio VGN-SR140E Hard Drive Replacement: 手順 7、 2の画像 2
    • Use the spudger or a fingernail to carefully release the lock securing the ribbon cable to the motherboard.
  8. Sony Vaio VGN-SR140E Hard Drive Replacement: 手順 8、 2の画像 1 Sony Vaio VGN-SR140E Hard Drive Replacement: 手順 8、 2の画像 2
    • Grasp the ribbon cable carefully near the connector end. Remove it by pulling the cable away from the connector on the motherboard at a slightly upward angle.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jeremy
メンバー登録日: 03/18/15
722 ポイント
4のガイドは作成済み
チーム
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G6
2 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 10
今までの合計 926
