メインコンテンツにスキップ
はじめに
The battery must be removed before any other part is serviced or replaced. The CD/DVD drive is secured with two screws. To access the two screws holding in the CD/DVD drive, the hard drive and RAM covers must be removed. When the screws are removed, the CD/DVD drive slides easily out of the laptop.
パーツ
パーツは指定されていません。
  1. Turn the laptop over and orient it as shown in the figure.
    • Turn the laptop over and orient it as shown in the figure.
  2. Slide the lock latch to the right to release the battery lock.
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop. Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Use a Phillips #1 screwdriver to loosen all four screws. These screws are secured to their covers with retaining clips.
    • Use a Phillips #1 screwdriver to loosen all four screws. These screws are secured to their covers with retaining clips.
  5. Lift the two covers with a fingernail or plastic opening tool from the sides the screws were present. Two tabs are securing the covers on the side opposite the screws.
    • Lift the two covers with a fingernail or plastic opening tool from the sides the screws were present. Two tabs are securing the covers on the side opposite the screws.
  6. Use a Phillips #1 screwdriver to remove both 6.5mm screws and set them aside.
    • Use a Phillips #1 screwdriver to remove both 6.5mm screws and set them aside.
  7. Gently slide the CD/DVD drive out of the laptop.
    • Gently slide the CD/DVD drive out of the laptop.
終わりに
Jeremy
メンバー登録日: 2015年03月18日
694 ポイント
4のガイドは作成済み
チーム
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015人のメンバー
MTU-LAUER-S15S1G6
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 13
今までの合計 421
