メインコンテンツにスキップ
Sony Vaio PCG-4G1L Hard Drive Replacement
必要な工具と部品
  1. Sony Vaio PCG-4G1L Hard Drive  Replacement, Battery: 手順 1、 1の画像 1
    • Turn off the computer and disconnect the charging cable.
    • Failing to unplug the cable can result in electric shock.
  2. Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 2、 2の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 2、 2の画像 2
    • Slide battery release toggle switch towards the "RELEASE" print.
  3. Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 3、 3の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 3、 3の画像 2 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 3、 3の画像 3
    • Apply pressure with your thumb on the grip.
    • Pull the battery out while simultaneously holding the battery release toggle switch in the release position.
  4. Sony Vaio PCG-4G1L Hard Drive  Replacement, Keyboard: 手順 4、 2の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement, Keyboard: 手順 4、 2の画像 2
    • Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
  5. Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 5、 2の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 5、 2の画像 2
    • Be sure to pry the plastic opening tool under the keyboard, rather than under the keys. Otherwise, some keys could get harmed.
    • While using a plastic opening tool, carefully lift the keyboard by inserting the tool under the edge.
  6. Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 6、 3の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 6、 3の画像 2 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 6、 3の画像 3
    • Do not pull the keyboard too far away, as a ribbon cable is still attached. Failing to do so can cause damage to the ribbon cable or the connector.
    • Use the plastic opening tool to release the clamp.
    • Using slight pressure, remove the ribbon cable with your fingers.
  7. Sony Vaio PCG-4G1L Hard Drive  Replacement, Network Antenna: 手順 7、 1の画像 1
    • Swivel the Network Antenna up so that it points upward.
  8. Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 8、 2の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 8、 2の画像 2
    • Pinch thumb and index finger at the Network Antenna's base.
    • Make sure not to bend the Network Antenna. Failing to do so can cause damage to the antenna.
    • Pull the Network Antenna off.
  9. Sony Vaio PCG-4G1L Hard Drive  Replacement, Plastic Casing: 手順 9、 2の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement, Plastic Casing: 手順 9、 2の画像 2
    • Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
  10. Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 10、 2の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 10、 2の画像 2
    • Remove one 7 mm Phillips #1 Pan Head Screw by using a Bit Driver with Phillips PH1 bit.
  11. Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 11、 2の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 11、 2の画像 2
    • Disconnect the cable by using the precision tweezers.
    • Slowly pry out the ribbon cable by using the plastic opening tool.
  12. Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 12、 1の画像 1
    • Do not pull the plastic cover too far away, as a ribbon cable is still attached. Failing to do so can cause damage to ribbon cable or the connector.
    • Remove the plastic cover by inserting the plastic opening tool around the edge.
  13. Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 13、 2の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 13、 2の画像 2
    • Disconnect the ribbon cable by pulling straight up with your fingers.
  14. Sony Vaio PCG-4G1L Hard Drive  Replacement, Hard Drive: 手順 14、 2の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement, Hard Drive: 手順 14、 2の画像 2
    • Remove three 5 mm Phillips #0 flat head screws using a Bit Driver with a Phillips PH000 bit.
    • Remove the bracket with your fingers.
  15. Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 15、 3の画像 1 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 15、 3の画像 2 Sony Vaio PCG-4G1L Hard Drive  Replacement: 手順 15、 3の画像 3
    • Using the plastic opening tool, pry out the side of the hard drive.
    • The hard drive should easily disconnect from the connector.
    • Slide the hard drive out, towards the left side of the case, while your fingers apply pressure to the ribbon cable.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Diego Fabiano
メンバー登録日: 10/04/16
177 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 2-3, Cagle Fall 2016 USF Tampa, Team 2-3, Cagle Fall 2016人のメンバー
USFT-CAGLE-F16S2G3
5 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 28
過去 30 日: 134
今までの合計 9,399
