はじめに
This replacement guide demonstrates how to remove the fan from a Sony VAIO PCG-3C2L. The fan is responsible for circulating air throughout the device, regulating the device’s temperature. Dust particles can accumulate on the fan blades over time, degrading its cooling capabilities and thus degrading overall device performance. It is generally recommended to remove the fan for cleaning once a year.
必要な工具と部品
Turn your computer over so the bottom is facing up.
The battery should be in the top on the back of the computer.
Remove the six 8 mm edge screws from the back panel using a Phillips #0 screwdriver.
Remove the two 8 mm corner screws from the back panel using a Phillips #0 screwdriver.
Remove the four 8 mm middle screws from the back panel using a Phillips #0 screwdriver.
Remove the three 2 mm screws from the back panel using a Phillips #0 screwdriver.
