はじめに
Are your speakers in your Sony Vaio PCG-161L no longer working? You can replace them in 30 minutes using this guide.
必要な工具と部品
Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
