メインコンテンツにスキップ
Sony Vaio Fit SVF15N26CXB Hard Drive Replacement
必要な工具と部品
  1. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Battery: 手順 1、 2の画像 1 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Battery: 手順 1、 2の画像 2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 2、 2の画像 1 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 2、 2の画像 2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 3、 3の画像 1 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 3、 3の画像 2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 3、 3の画像 3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 4、 1の画像 1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Hard Drive: 手順 5、 2の画像 1 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement, Hard Drive: 手順 5、 2の画像 2
    • Remove the four 3.20mm Phillips #00 screws from the hard drive.
  6. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 6、 3の画像 1 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 6、 3の画像 2 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 6、 3の画像 3
    • Use a spudger to flip up the black latch on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors and fold them over the hard drive.
    • Disconnect the hard drive and remove.
  7. Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 7、 2の画像 1 Sony Vaio Fit SVF15N26CXB Hard Drive Replacement: 手順 7、 2の画像 2
    • Remove the four 3.70mm Phillips #00 screws from the hard drive mounting case.
    • Carefully peel foil tray off of hard drive.
終わりに
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Althea McDavid
メンバー登録日: 02/14/18
857 ポイント
6のガイドは作成済み
チーム
USF Tampa, Team S2-G4, Nance Spring 2018 USF Tampa, Team S2-G4, Nance Spring 2018人のメンバー
USFT-NANCE-S18S2G4
4 メンバー
12のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 16
今までの合計 1,158
