メインコンテンツにスキップ
Sony Vaio Fit SVF14A190X Hard Drive Replacement
必要な工具と部品
  1. Sony Vaio Fit SVF14A190X Hard Drive Replacement, Battery Replacement: 手順 1、 1の画像 1
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X Hard Drive Replacement: 手順 2、 3の画像 1 Sony Vaio Fit SVF14A190X Hard Drive Replacement: 手順 2、 3の画像 2 Sony Vaio Fit SVF14A190X Hard Drive Replacement: 手順 2、 3の画像 3
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X Hard Drive Replacement: 手順 3、 3の画像 1 Sony Vaio Fit SVF14A190X Hard Drive Replacement: 手順 3、 3の画像 2 Sony Vaio Fit SVF14A190X Hard Drive Replacement: 手順 3、 3の画像 3
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X Hard Drive Replacement: 手順 4、 2の画像 1 Sony Vaio Fit SVF14A190X Hard Drive Replacement: 手順 4、 2の画像 2
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
  5. Sony Vaio Fit SVF14A190X Hard Drive Replacement, Hard Drive Replacement: 手順 5、 3の画像 1 Sony Vaio Fit SVF14A190X Hard Drive Replacement, Hard Drive Replacement: 手順 5、 3の画像 2 Sony Vaio Fit SVF14A190X Hard Drive Replacement, Hard Drive Replacement: 手順 5、 3の画像 3
    • Use the Phillips head screw driver to remove four 4mm screws located on both sides of the hard drive.
  6. Sony Vaio Fit SVF14A190X Hard Drive Replacement: 手順 6、 2の画像 1 Sony Vaio Fit SVF14A190X Hard Drive Replacement: 手順 6、 2の画像 2
    • Use a plastic opening tool to lift the hard drive up to the point where it can be grabbed.
    • Pull the hard drive horizontally to separate it from it's connection.
終わりに
作成者
4人の作成者と共同で作成されました。
Ryan Silberger
メンバー登録日: 02/13/18
109 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team S11-G3, Cheng Spring 2018 USF Tampa, Team S11-G3, Cheng Spring 2018人のメンバー
USFT-CHENG-S18S11G3
4 メンバー
11のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 822
