はじめに
If your Sony Vaio Fit 13A ( model SVF13NA1EL) is making excessive noise or is getting too warm, as described in the troubleshooting page for this laptop, the problem may be caused by a dirty or broken fan. This guide will show you how to open your laptop and clean the fan. If cleaning does not fix the problem then this guide will also show how to replace the fan.
Before beginning make sure the laptop is powered off.
必要な工具と部品
ある他の人がこのガイドを完成しました。
