メインコンテンツにスキップ
Sony Vaio Fit 13A Charger Port Replacement
必要な工具と部品
  1. Sony Vaio Fit 13A Charger Port Replacement, Back Cover: 手順 1、 2の画像 1 Sony Vaio Fit 13A Charger Port Replacement, Back Cover: 手順 1、 2の画像 2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Charger Port Replacement: 手順 2、 2の画像 1 Sony Vaio Fit 13A Charger Port Replacement: 手順 2、 2の画像 2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Charger Port Replacement: 手順 3、 1の画像 1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Charger Port Replacement, Fan: 手順 4、 2の画像 1 Sony Vaio Fit 13A Charger Port Replacement, Fan: 手順 4、 2の画像 2
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  5. Sony Vaio Fit 13A Charger Port Replacement: 手順 5、 3の画像 1 Sony Vaio Fit 13A Charger Port Replacement: 手順 5、 3の画像 2 Sony Vaio Fit 13A Charger Port Replacement: 手順 5、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to carefully unplug the fan connector.
  6. Sony Vaio Fit 13A Charger Port Replacement, Remove the Fan: 手順 6、 2の画像 1 Sony Vaio Fit 13A Charger Port Replacement, Remove the Fan: 手順 6、 2の画像 2
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
  7. Sony Vaio Fit 13A Charger Port Replacement, Charger Port: 手順 7、 3の画像 1 Sony Vaio Fit 13A Charger Port Replacement, Charger Port: 手順 7、 3の画像 2 Sony Vaio Fit 13A Charger Port Replacement, Charger Port: 手順 7、 3の画像 3
    • Remove 1mm screw using a Phillips Head #0 screwdriver.
    • Remove two 3mm screws using a Phillips Head #1 screwdriver.
  8. Sony Vaio Fit 13A Charger Port Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    • Use tweezers to carefully remove the charger port cover.
  9. Sony Vaio Fit 13A Charger Port Replacement, Unplug the Port: 手順 9、 2の画像 1 Sony Vaio Fit 13A Charger Port Replacement, Unplug the Port: 手順 9、 2の画像 2
    • Gently unplug charger port from motherboard using tweezers.
終わりに
6 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Marii
メンバー登録日: 01/08/15
658 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 21-19, Maness Winter 2015 Cal Poly, Team 21-19, Maness Winter 2015人のメンバー
CPSU-MANESS-W15S21G19
4 メンバー
12のガイドは作成済み
5 件のコメント
Excellent instructions, thank you. Now all I need to do is overcome fear, buy some tools and magnifiers, knock on wood and go for it. But I think I'll wait until I can no longer find the sweet spot.
rkotomori - 返信
Where can I buy the charge port?
patrickchughes - 返信
Hi Patrick
this is the same question I have. Did you managed to find one in the meantime ?
Or does anaybody know where to buy one ?
thanx for any help !
cheers
B
Ben - 返信
Don't even bother it will just fail again in a few weeks
I am going to try and redesign it
I already replaced mine and it just failed again
Not even a month later and it was very expensive and nearly impossible to find ,the design is faulty Sony should be sued for releasing this dangerous product
I have to hold it on the "sweet spot" the entire time I am using the computer and constantly reposition it
And it gets 🔥 HOT
Hot enough to burn my fingers
!#^& poor design and it never should have been released like this someone should have realized this this POS is a house fire waiting to happen
anthony rossetti - 返信
I misplaced the old one I took out but I plan on finding it and altering it to include a normal barrel jack instead
Or designing and 3D printing a housing for barrel jack and using the connector that plugs into the motherboard from the old one for the redesigned one
The changing the end on the charger as well ,since I already bought a couple of those before I realized it was the port ,the only solution would be to redesign it to be like normal barrel jack because it will just keep on failing
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 25
今までの合計 4,248
