はじめに
This is a brief guide for the Li-ion battery replacement of Sony Vaio Duo 13.
In this guide, a swollen Li-ion battery is replaced with a new one as a demonstration.
Replacing the old or damaged Li-ion battery is not only improves the performance of the laptop, but also keeps the battery in a healthy state for safety, avoiding the risk of thermal runaway.
Step descriptions:
- Step 1: Check the appearance of the laptop before replacement
- Step 2: Check the status of the battery before replacement (optional)
- Step 3~11: Teardown the laptop until the Li-ion battery appears
- Step 12~13: Remove the old or damaged Li-ion battery
- Step 14~15: Replace the old double-sided tapes (optional)
- Step 16: Install new Li-ion battery
- Step 17~18: Stick back the plastic sheet and double-sided tape
- Step 19: Spacing fixing (optional)
- Step 20: Check the laptop after replacing the battery
- Step 21: Check the status of the battery after replacement (optional)
NOTE:
- There is a "destructive" teardown that cannot be restored to its original state in step 9.
- Steps 2 and 21 can be skipped when users don't want to know the status of the battery or don't have the software.
- Steps 14~15 and 19 can be skipped when old double-sided tapes still provide sufficient stickiness.
必要な工具と部品
Please check the appearance before fixing the laptop. For example: The laptop has been spread by the battery inside (up to 5 mm).
This is an optional step. This step can be skipped when users don't want to know the battery status or don't have the software.
Check the "cycle times" by battery software.
Suggested software: (1) BatteryInfoView, (2) BatteryMon.
Background: The number of "cycle times" depends on battery usage. It usually > 0. A Li-ion battery usually has "cycle times" about 500~1000. REF: https://doi.org/10.31224/osf.io/swcyg
For example: BatteryInfoView shows that "Number of charge/discharge cycles" is 306 (red box). BatteryMon shows that "Charge cycles" is 306 (blue box).
Go to the back side of the laptop.
Remove the screw with a "+" screwdriver (the red circle).
Number of screws: 1
Rotate the laptop 180°.
Follow the direction of the red arrow and open the backside of the laptop from the open side, where the cooling cooper tube can be obviously been seen.
The swollen Li-ion battery appears (the white package).
Remove the screws with a "+" screwdriver (red circles).
Number of screws: 7
Condition: The double-sided tape of the plastic part is degummed and has lost its stickiness. The plastic part clearly leaves the surface.
Remove the double-sided tape that has lost its stickiness.
Use new double-sided tape.
Paste the plastic part back to its original position.
Do the same on the other side if necessary.
Suggestion: Do the same on the other side even though the plastic part sticks right on the surface. Because the old double-sided tape might not provide sufficient stickiness.
Other methods: The epoxy AB glue can replace the double-sided tape.
Plug the cable into the new Li-ion battery gently and tightly.
To reassemble the laptop, follow steps 3~11 in reverse order. Some possible conditions and how to handle them will be described in the following steps.
Condition: The stickiness of the old double-sided tape (black) is not sufficient to stick back the plastic sheet (silver).
Use new double-sided tape (white) to stick the plastic sheet and the old double-sided tape.
Condition: If the stickiness of the double-sided tape is not sufficient, causing a spacing.
Suggested method: Repeat steps 14 and 15.
Other methods: Use tape to fix the problem. In this case, the yellow tapes are used for the clear demonstration. Users can use other color tapes.
After replacing the battery, please check the appearance of the laptop.
Please turn on the laptop and unplug the AC power line to check the functionality of the battery.
For example: BatteryInfoView shows that "Number of charge/discharge cycles" is 0 (red box), indicating that the laptop treats the battery as a new one.
This brief guide provides a simple Li-ion battery replacement procedure for Sony Vaio Duo 13.
3 の人々がこのガイドを完成させました。
