はじめに
This will guide you in replacing the Power Button of a Sony VAIO VPCF 132FX.
必要な工具と部品
Remove the screws and flip it back.
you need to remove also all the screws from the bottom sides in order to detach the panel!
5 の人々がこのガイドを完成させました。
4 件のコメント
My power on button was broken where the part you depress was detached from the little circuit board because the plastic holder was broke. Rather than buy a new switch assembly I simply lined everything up in the case and use a liberal amount of RTV to hold everything in place. The RTV is flexible enough to allow the plunger to depress the switch on the board and then spring back into place. It has work great this way since I fixed it six months ago.
I need a similar or identical part for my Sony VGN-TT130N notebook. Where can I find and purchase this power button assembly?
Did you ever find where to buy the part?
bonjour mon sony vaio led power vert ne allume pas mais pc marche bien .et ce que je peut active led pawer ?
