メインコンテンツにスキップ
Sony VAIO PCG-F360 Speaker Replacement
必要な工具と部品
  1. Sony VAIO PCG-F360 Speaker Replacement, Battery: 手順 1、 1の画像 1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony VAIO PCG-F360 Speaker Replacement: 手順 2、 1の画像 1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony VAIO PCG-F360 Speaker Replacement: 手順 3、 1の画像 1
    • Use the indentations to pull the old battery out.
  4. Sony VAIO PCG-F360 Speaker Replacement: 手順 4、 1の画像 1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony VAIO PCG-F360 Speaker Replacement, Speaker Panel: 手順 5、 3の画像 1 Sony VAIO PCG-F360 Speaker Replacement, Speaker Panel: 手順 5、 3の画像 2 Sony VAIO PCG-F360 Speaker Replacement, Speaker Panel: 手順 5、 3の画像 3
    • There are two screws on the left hand side of the laptop near the IR receiver. remove them using a #00 Philips head screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony VAIO PCG-F360 Speaker Replacement: 手順 6、 3の画像 1 Sony VAIO PCG-F360 Speaker Replacement: 手順 6、 3の画像 2 Sony VAIO PCG-F360 Speaker Replacement: 手順 6、 3の画像 3
    • Push the beige tab in the direction of the ribbon. it should only move a small amount
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
  7. Sony VAIO PCG-F360 Speaker Replacement, Speaker: 手順 7、 2の画像 1 Sony VAIO PCG-F360 Speaker Replacement, Speaker: 手順 7、 2の画像 2
    • The two speakers are located on the ends of the panel.
    • There are two screws holding each speaker. Remove them using a #00 Philips head screw driver.
  8. Sony VAIO PCG-F360 Speaker Replacement: 手順 8、 1の画像 1
    • Carefully flip the speaker over and replace or clean the needed parts.
終わりに
作成者
1人の作成者と共同作成されました。
Hannah Millea
メンバー登録日: 03/11/14
401 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team 3-5, Calaway Spring 2014 UMass Dartmouth, Team 3-5, Calaway Spring 2014人のメンバー
UMASSD-CALAWAY-S14S3G5
2 メンバー
4のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 202
