メインコンテンツにスキップ
Sony VAIO PCG-933A Keyboard Replacement
必要な工具と部品
  1. Sony VAIO PCG-933A Keyboard Replacement, Battery: 手順 1、 2の画像 1 Sony VAIO PCG-933A Keyboard Replacement, Battery: 手順 1、 2の画像 2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Keyboard Replacement: 手順 2、 3の画像 1 Sony VAIO PCG-933A Keyboard Replacement: 手順 2、 3の画像 2 Sony VAIO PCG-933A Keyboard Replacement: 手順 2、 3の画像 3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Sony VAIO PCG-933A Keyboard Replacement, Keyboard: 手順 3、 1の画像 1
    • Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
  4. Sony VAIO PCG-933A Keyboard Replacement: 手順 4、 2の画像 1 Sony VAIO PCG-933A Keyboard Replacement: 手順 4、 2の画像 2
    • Remove the 4mm screw on the right rear side of the laptop next to the audio ports using a Phillips #0 screwdriver.
    • This will release the speaker grille.
  5. Sony VAIO PCG-933A Keyboard Replacement: 手順 5、 1の画像 1
    • Flip the computer so the key board is facing up.
  6. Sony VAIO PCG-933A Keyboard Replacement: 手順 6、 3の画像 1 Sony VAIO PCG-933A Keyboard Replacement: 手順 6、 3の画像 2 Sony VAIO PCG-933A Keyboard Replacement: 手順 6、 3の画像 3
    • Slide the blue speaker grille (located above the keyboard) to the right and gently pull upward. The grille will still be connected by a white electrical strip.
    • Carefully pull out the white electrical strip. By doing this you will remove the speaker grille.
  7. Sony VAIO PCG-933A Keyboard Replacement: 手順 7、 3の画像 1 Sony VAIO PCG-933A Keyboard Replacement: 手順 7、 3の画像 2 Sony VAIO PCG-933A Keyboard Replacement: 手順 7、 3の画像 3
    • Remove the 4mm screw in the center using a Phillips screwdriver.
    • Carefully and slowly pull the green strip straight up (away from the laptop) to disconnect it. Make sure not to pull too hard to avoid breaking.
    • The keyboard can now be removed.
終わりに
作成者
7人の作成者と共同で作成されました。
Sara Lillard
メンバー登録日: 04/11/11
165 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011人のメンバー
CPSU-MANESS-S11S12G36
4 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,799
