はじめに
This repair guide illustrates how to replace the Floppy Disk Drive.
ツール
工具は必要ありません。
パーツ
パーツは必要ありません。
  1. Turn the laptop upside down
    • Turn the laptop upside down
    • The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
    • With the laptop facing you, turn the laptop upside down.
    • Locate the release switch in the center of the laptop, shown here.
    • Slide the switch, and hold in place. The floppy disk drive is now free and should easily slide out.
    • To replace, insert the new floppy disk drive with the wording facing down.
まとめ
Sara Lillard
メンバー登録日: 2011年04月11日
117 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011人のメンバー
CPSU-MANESS-S11S12G36
4 メンバー
8のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 1,629
