メインコンテンツにスキップ
Sony VAIO VPCEC1M1E Keyboard Replacement
必要な工具と部品
  1. Sony VAIO VPCEC1M1E Keyboard Replacement, Keyboard: 手順 1、 1の画像 1
    • Remove the following color-coded screws:
    • These screws secure the RAM and hard drive covers, respectively.
    • These screws secure the optical drive to the lower case of the laptop.
    • The various other screws highlighted in the picture are unnecessary to remove and should be done at your own discretion.
  2. Sony VAIO VPCEC1M1E Keyboard Replacement: 手順 2、 1の画像 1
    • Remove the following screws:
    • Five screws highlighted in orange.
    • Two screws highlighted in blue.
    • Pry the hard drive connector upwards from its socket on the logic board.
  3. Sony VAIO VPCEC1M1E Keyboard Replacement: 手順 3、 1の画像 1
    • Release the highlighted clips to remove the upper case of the keyboard.
  4. Sony VAIO VPCEC1M1E Keyboard Replacement: 手順 4、 3の画像 1 Sony VAIO VPCEC1M1E Keyboard Replacement: 手順 4、 3の画像 2 Sony VAIO VPCEC1M1E Keyboard Replacement: 手順 4、 3の画像 3
    • Flip up the retaining flap (highlighted in red) on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap and not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the laptop.
ゴール
7 の人々がこのガイドを完成させました。
作成者
7人の作成者と共同で作成されました。
Stephan
メンバー登録日: 08/20/11
199 ポイント
1ガイドが承認済み
3 件のコメント
Very useful, thank you. A real pain to do though without snapping the plastic tabs on the upper case.
Eddie B - 返信
OMG... guys, you need just unscrew FOUR screws on the bottom (two orange circles on the same level that yellow sticker and two orange-circled screws in the middle of left and right side) and then pop the keyboard up with knife, etc, and disconnect the cable.
Paul G - 返信
agree with Paul G. you don’t need to remove all the plastic case to change the keyboard
Pierret -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 30
今までの合計 23,020
