はじめに
The power board only needs to be replaced if the device can not turn on and all other troubleshooting options have been attempted. When dealing with a power board, be careful of the capacitors as they can hold charge and shock you. Unplug device before starting.
必要な工具と部品
Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
Slide both covers back about a 1/2 inch, then pull them away from the case.
Disconnect the power cable connector and motherboard connector from the power board.
