はじめに
Your disc drive begins to start malfunctioning, clicks or makes weird sound when you go to eject, or fails to read the disc [knowing you are using a good disc].
必要な工具と部品
Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
Slide both covers back about a 1/2 inch, then pull them away from the case.
Find and remove the three ribbon connections leading to the motherboard.
Gently pull straight up. Be careful because ribbon cables are fragile.
もう少しです!
終わりに
