メインコンテンツにスキップ
Sony UBP-UX80 Bluetooth Card Replacement
必要な工具と部品
  1. Sony UBP-UX80 Bluetooth Card Replacement, Top Cover: 手順 1、 3の画像 1 Sony UBP-UX80 Bluetooth Card Replacement, Top Cover: 手順 1、 3の画像 2 Sony UBP-UX80 Bluetooth Card Replacement, Top Cover: 手順 1、 3の画像 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
    • Slide both covers back about a 1/2 inch, then pull them away from the case.
  2. Sony UBP-UX80 Bluetooth Card Replacement: 手順 2、 3の画像 1 Sony UBP-UX80 Bluetooth Card Replacement: 手順 2、 3の画像 2 Sony UBP-UX80 Bluetooth Card Replacement: 手順 2、 3の画像 3
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws on the side of the case, each connecting to a tab on the cover.
    • Similar to the previous step, it is identical cases on both sides of the device.
    • Use a Phillips #2 screwdriver to remove the two 10.5 mm screws (one next to the Wi-Fi logo and one next to the Blu-ray logo).
  3. Sony UBP-UX80 Bluetooth Card Replacement: 手順 3、 2の画像 1 Sony UBP-UX80 Bluetooth Card Replacement: 手順 3、 2の画像 2
    • Press in the tabs found on the front-sides of the case (connected to the front panel).
    • Slide the top cover forward.
    • Lift off the case.
  4. Sony UBP-UX80 Bluetooth Card Replacement: 手順 4、 3の画像 1 Sony UBP-UX80 Bluetooth Card Replacement: 手順 4、 3の画像 2 Sony UBP-UX80 Bluetooth Card Replacement: 手順 4、 3の画像 3
    • Find the eleven 10.5 mm silver screws and two 6 mm black screws on the perimeter of the silver cover plate.
    • Remove the silver screws using a Phillips #2 screwdriver and the black ones using a Phillips #1 screwdriver.
    • Life the back of the cover up and off of the chasis.
  5. Sony UBP-UX80 Bluetooth Card Replacement, Front Cover: 手順 5、 3の画像 1 Sony UBP-UX80 Bluetooth Card Replacement, Front Cover: 手順 5、 3の画像 2 Sony UBP-UX80 Bluetooth Card Replacement, Front Cover: 手順 5、 3の画像 3
    • Toward the panel there is a ribbon cable with 4 small black pieces of tape holding it down
    • Pull directly up on the ribbon cable to disconnect it from the motherboard
    • Gently pull the cable back away from the motherboard pulling the tape off with it
  6. Sony UBP-UX80 Bluetooth Card Replacement: 手順 6、 1の画像 1
    • Once all pieces of tape have been pulled up, the ribbon cable should look like this.
  7. Sony UBP-UX80 Bluetooth Card Replacement: 手順 7、 2の画像 1 Sony UBP-UX80 Bluetooth Card Replacement: 手順 7、 2の画像 2
    • There are screws on every side of the front panel holding it in. Use a #2 Phillips head screwdriver to remove the nine screws.
    • Unscrew the three 10.5 mm long ph #2 screws on the top.
    • Unscrew the four 10.5 mm long ph #2 screws on the bottom.
  8. Sony UBP-UX80 Bluetooth Card Replacement: 手順 8、 2の画像 1 Sony UBP-UX80 Bluetooth Card Replacement: 手順 8、 2の画像 2
    • Use a Phillips #2 screwdriver to remove the 10.5 mm screws, one on each side of the device.
  9. Sony UBP-UX80 Bluetooth Card Replacement: 手順 9、 3の画像 1 Sony UBP-UX80 Bluetooth Card Replacement: 手順 9、 3の画像 2 Sony UBP-UX80 Bluetooth Card Replacement: 手順 9、 3の画像 3
    • Lift tab on the left side of the device
    • Work your way right, lifting the next tabs. One on the bottom and one the Top
    • Continue working the tabs on the top and bottom, keeping them from snapping back in place.
  10. Sony UBP-UX80 Bluetooth Card Replacement: 手順 10、 1の画像 1
    • Once all tabs are disconnected, pull the front panel forward to fully disconnect it
  11. Sony UBP-UX80 Bluetooth Card Replacement, Bluetooth Card: 手順 11、 1の画像 1
    • Once you have the front panel removed the Bluetooth card is located on the left side of the device.
  12. Sony UBP-UX80 Bluetooth Card Replacement: 手順 12、 2の画像 1 Sony UBP-UX80 Bluetooth Card Replacement: 手順 12、 2の画像 2
    • Gently remove the small brass connection, remove it, being careful not to break the connector or the wire as they are very small.
    • Once the wire has been gently removed, this should be the end result.
  13. Sony UBP-UX80 Bluetooth Card Replacement: 手順 13、 1の画像 1
    • Remove the single 10.5mm screw securing the card to the chassis using the #2 Phillips head screwdriver.
  14. Sony UBP-UX80 Bluetooth Card Replacement: 手順 14、 1の画像 1
    • Pull the card away from the chassis to remove it.
終わりに
作成者
2人の作成者と共同で作成されました。
Nate Picard
メンバー登録日: 03/13/23
349 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 2-5, Petersen Spring 2023 UMass Dartmouth, Team 2-5, Petersen Spring 2023人のメンバー
UMASSD-PETERSEN-S23S2G5
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 19
今までの合計 64
