メインコンテンツにスキップ
Sony Tablet S Battery Replacement
必要な工具と部品
  1. Sony Tablet S Battery Replacement, Battery: 手順 1、 2の画像 1 Sony Tablet S Battery Replacement, Battery: 手順 1、 2の画像 2
    • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
    • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
  2. Sony Tablet S Battery Replacement: 手順 2、 1の画像 1
    • Remove the two 10mm Phillips #0 screws located under the grips.
  3. Sony Tablet S Battery Replacement: 手順 3、 2の画像 1 Sony Tablet S Battery Replacement: 手順 3、 2の画像 2
    • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
    • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
  4. Sony Tablet S Battery Replacement: 手順 4、 1の画像 1
    • Once the casing is off, remove the nine 5mm Phillips #0 screws shown.
  5. Sony Tablet S Battery Replacement: 手順 5、 1の画像 1
    • Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
    • Use caution when removing the cable, as the socket is very fragile.
  6. Sony Tablet S Battery Replacement: 手順 6、 1の画像 1
    • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
  7. Sony Tablet S Battery Replacement: 手順 7、 1の画像 1
    • Slide the bottom grey cover piece away from the body and remove it.
    • If this piece gives resistance, use a spudger on the sides of the tablet to pry it loose.
  8. Sony Tablet S Battery Replacement: 手順 8、 1の画像 1
    • Remove the five 4mm Phillips #000 screws.
    • Remove the two 5mm Phillips #000 screws holding the charger in place.
  9. Sony Tablet S Battery Replacement: 手順 9、 3の画像 1 Sony Tablet S Battery Replacement: 手順 9、 3の画像 2 Sony Tablet S Battery Replacement: 手順 9、 3の画像 3
    • Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
    • If the cover is not coming off easily, use a plastic opening tool to pry it loose from the edges of the screen.
  10. Sony Tablet S Battery Replacement: 手順 10、 2の画像 1 Sony Tablet S Battery Replacement: 手順 10、 2の画像 2
    • Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
  11. Sony Tablet S Battery Replacement: 手順 11、 1の画像 1
    • Remove the three 5mm Phillips #0 screws securing the original battery.
  12. Sony Tablet S Battery Replacement: 手順 12、 2の画像 1 Sony Tablet S Battery Replacement: 手順 12、 2の画像 2
    • Use the spudger to pop the battery loose and remove the battery.
終わりに
4 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Austin Mann
メンバー登録日: 09/28/16
287 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 3-5, Passmore Fall 2016 USF Tampa, Team 3-5, Passmore Fall 2016人のメンバー
USFT-PASSMORE-F16S3G5
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 6
過去 30 日: 21
今までの合計 2,570
