メインコンテンツにスキップ
Sony TCM-919 Cassette-Corder Motherboard Replacement
必要な工具と部品
  1. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Back Cover: 手順 1、 1の画像 1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Motherboard Replacement, Back Cover Screw Removal: 手順 2、 1の画像 1
    • Remove the 5 5.95mm screws as indicated in the picture using the Phillips Head screwdriver.
  3. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove 3-Digit Tape Counter: 手順 3、 2の画像 1 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove 3-Digit Tape Counter: 手順 3、 2の画像 2
    • Locate the 3-digit tape counter and gently push the tabs apart releasing the counter.
    • Pull the 3-digit tape counter out.
    • Remove the rubber band attaching the 3-digit tape counter to the cassette head.
  4. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motor: 手順 4、 2の画像 1 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motor: 手順 4、 2の画像 2
    • Remove the screws as indicated in the picture using the Phillips Head screwdriver.
    • Pull the loosened motor out of the device, and set the motor aside.
  5. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: 手順 5、 3の画像 1 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: 手順 5、 3の画像 2 Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove the Tape Deck: 手順 5、 3の画像 3
    • Removes the 3, 5.95mm screws using the Phillips Head screwdriver as indicated by picture 1.
    • Push firmly on the tabs and lift the tape deck out.
    • Set the tape deck aside.
  6. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Motherboard Screws: 手順 6、 1の画像 1
    • Remove the 2 5.95mm screws as indicated by the picture using the Phillips Head screwdriver.
  7. Sony TCM-919 Cassette-Corder Motherboard Replacement, Remove Epoxy: 手順 7、 1の画像 1
    • Remove the epoxy completely from the motherboard so that the wires underneath the epoxy can move freely.
  8. Sony TCM-919 Cassette-Corder Motherboard Replacement, Desolder Wires From Motherboard: 手順 8、 2の画像 1 Sony TCM-919 Cassette-Corder Motherboard Replacement, Desolder Wires From Motherboard: 手順 8、 2の画像 2
    • Remove the motherboard from case.
    • Flip the motherboard around so that the metallic green side is facing you.
    • Desolder the points indicated in picture 2. This should free the wires connected to the motherboard.
    • Remove the motherboard by pulling it out of the device cavity.
終わりに
作成者
3人の作成者と共同で作成されました。
Marygayle Martin
メンバー登録日: 10/23/14
506 ポイント
5のガイドは作成済み
チーム
Baylor, Team 4-3, Williams Fall 2014 Baylor, Team 4-3, Williams Fall 2014人のメンバー
BU-WILLIAMS-F14S4G3
3 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 1,710
