はじめに
The Sony SRS-XE200 is a popular portable Bluetooth speaker that delivers high-quality sound with a compact design. However, like any electronic device, it may encounter issues that require repairs. One common problem that users may encounter is a malfunctioning motherboard. The motherboard is a critical component that controls the speaker's functions, including audio signal processing and power management. If the motherboard is damaged or fails, the speaker may not function correctly or turn on. In such cases, it may be necessary to replace the motherboard.
必要な工具と部品
Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
Separate the motherboard from the case.
コメント 1 件
Hy please I m from morrocco i need a matherbeard a have a speaker but not work i d'not no way i need help plz
