はじめに
If you notice that the microphone in your speaker has stopped working, this guide will show you the steps to take to reach the microphone and remove it for replacement. The majority of repair time will be spent attempting to open the device, as it is sealed shut by adhesive. Once open, the repair is straightforward.
Keep in mind that opening the speaker will nullify the IP67 (waterproof and dustproof) rating, and may cause slight external damage when attempting to open.
必要な工具と部品
To get the bottom part of the speaker off, take a long and sturdy screwdriver and put it through the holes at the bottom of the speaker.
When you have the screwdriver through the holes, you'll want to push down very firmly. Rotate between the holes and repeat this process until the bottom piece pops off.
