必要な工具と部品
To get the bottom part of the speaker off, take a long and sturdy screwdriver and put it through the holes at the bottom of the speaker.
When you have the screwdriver through the holes, you'll want to push down very firmly. Rotate between the holes and repeat this process until the bottom piece pops off.
Using the precision tweezers set, pinch the tabs on the electric plugins and gently pull outwards to disconnect the wires from the motherboard.
Insert a finger under the motherboard and gently lift it out of the casing.
Locate the four 11 mm screws along the base of the white center block.
Use the Phillips #1 screwdriver with the 150mm flex extension from the Mako Driver kit to unscrew and remove the screws from their positions.
Use the blunt tweezers from the precision tweezers set to clamp down on a solid piece of the white center block.
With a firm grip, pull upwards with the blunt tweezers until the white center block is released from its position.
Locate the small brackets along the side of the white center block that hold the red, yellow, black, and white wires in place.
With your fingers, gently pull the wires away from the center block so that they are no longer held up by the brackets.
Flip the white center block over so that the black speaker is facing upwards.
Firmly grasp the speaker with your hands and pull it up and away from the center block until it fully disconnects from it.
Follow the red, yellow, and black cables to below the speaker.
Using the iFixit spudger, pry the battery from the case.
ある他の人がこのガイドを完成しました。
コメント 1 件
Thanks to the people who put this article together for the Sony SRS-XB13 blue tooth speaker battery replacement. I have one of these speakers but is still pretty new and the battery replacement is a ways off. It's pretty clear Sony followed Apple small device battery replacement business model and both are PURE BS to begin with. Nothing user friendly about this process but being a power user I can digest it. Both companies deserve a slap upside the head for this type of industrial design on high utilization consumer devices. For the average consumer, this speaker becomes a BIC LIGHTER once the re-chargable battery BITES The Dust.... toss it and they do toss this stuff all too often. Someone get Joe (the Author) a job at SONY and show them how to make it right for the average consumer. Can someone forward this to an Exec at Sony...? That would be really cool and thanks in advance if done..... :)
