メインコンテンツにスキップ
Sony SRS-X55 Battery Replacement
必要な工具と部品
  1. Sony SRS-X55 Battery Replacement, Battery: 手順 1、 3の画像 1 Sony SRS-X55 Battery Replacement, Battery: 手順 1、 3の画像 2 Sony SRS-X55 Battery Replacement, Battery: 手順 1、 3の画像 3
    • Remove the six screw covers with a spudger.
    • Remove the six 11 mm Phillips screws from the bottom panel.
    • Remove the bottom panel of the speaker.
  2. Sony SRS-X55 Battery Replacement: 手順 2、 1の画像 1
    • Disconnect the battery cable from the motherboard.
    • Remove the battery.
終わりに
4 の人々がこのガイドを完成させました。
Bradley Conner
メンバー登録日: 01/31/16
169 ポイント
2のガイドは作成済み
チーム
University of Alabama, Team 1-3, Sydow campbell Spring 2016 University of Alabama, Team 1-3, Sydow campbell Spring 2016人のメンバー
UA-SYDOW CAMPBELL-S16S1G3
5 メンバー
5のガイドは作成済み
6 件のコメント
Anyone know where to buy the replacement batteries ?
Jed Pause - 返信
Where can I buy a replacement battery ? Thank YOu
Deanna - 返信
Please, do you know where I can buy a replacement batter ~ Thank you so much,
DJoy
Deanna - 返信
I was just looking at the battery Jed Pause and it is made in China, manufactured in China, assembled in China ~ so no batter available in America ~ have to go to China to get it! which is very likely that you can ~ Just bring the battery with you and show it to seller’s on the street. Someone will find you the right place ~
Deanna - 返信
Sorry, I was wrong, not China but Japan ~ I also just saw on the battery Japan only!!!
Deanna - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 28
今までの合計 5,397
