メインコンテンツにスキップ
Sony SRS-X5 USB/AUX plug in Replacement
必要な工具と部品
  1. Sony SRS-X5 USB/AUX plug in Replacement, Battery: 手順 1、 1の画像 1
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 USB/AUX plug in Replacement: 手順 2、 2の画像 1 Sony SRS-X5 USB/AUX plug in Replacement: 手順 2、 2の画像 2
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 USB/AUX plug in Replacement: 手順 3、 1の画像 1
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 USB/AUX plug in Replacement, Speaker: 手順 4、 1の画像 1
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
  5. Sony SRS-X5 USB/AUX plug in Replacement: 手順 5、 1の画像 1
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 USB/AUX plug in Replacement: 手順 6、 2の画像 1 Sony SRS-X5 USB/AUX plug in Replacement: 手順 6、 2の画像 2
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 USB/AUX plug in Replacement: 手順 7、 3の画像 1 Sony SRS-X5 USB/AUX plug in Replacement: 手順 7、 3の画像 2 Sony SRS-X5 USB/AUX plug in Replacement: 手順 7、 3の画像 3
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
  8. Sony SRS-X5 USB/AUX plug in Replacement, Bluetooth: 手順 8、 2の画像 1 Sony SRS-X5 USB/AUX plug in Replacement, Bluetooth: 手順 8、 2の画像 2
    • Unplug the cord connected to the motherboard by squeezing the plastic sides.
  9. Sony SRS-X5 USB/AUX plug in Replacement: 手順 9、 1の画像 1
    • Gently tug on the plastic ribbon connected to the bottom side of the speaker to unplug it.
  10. Sony SRS-X5 USB/AUX plug in Replacement: 手順 10、 1の画像 1
    • Remove the motherboard.
  11. Sony SRS-X5 USB/AUX plug in Replacement, USB/AUX plug in: 手順 11、 2の画像 1 Sony SRS-X5 USB/AUX plug in Replacement, USB/AUX plug in: 手順 11、 2の画像 2
    • Using the Phillips #1 screwdriver, remove the two 6mm screws holding the AUX board in place.
  12. Sony SRS-X5 USB/AUX plug in Replacement: 手順 12、 1の画像 1
    • Remove the aux board. Be careful as the board might need some wiggling to get out.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Jeffrey Yalung
メンバー登録日: 09/28/16
460 ポイント
3のガイドは作成済み
チーム
Eastern Washington University, Team 2-6, Mathisen Fall 2016 Eastern Washington University, Team 2-6, Mathisen Fall 2016人のメンバー
EWU-MATHISEN-F16S2G6
4 メンバー
5のガイドは作成済み
2 件のコメント
hi there, where can i buy aux board for replacement? thank you
Khánh Trần - 返信
Donde puedo conseguir la tarjeta?
Alan Castaneda - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 14
今までの合計 1,660
