メインコンテンツにスキップ
Sony SRS-X5 Battery Replacement
必要な工具と部品
  1. Sony SRS-X5 Battery Replacement, Battery: 手順 1、 1の画像 1
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 Battery Replacement: 手順 2、 2の画像 1 Sony SRS-X5 Battery Replacement: 手順 2、 2の画像 2
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 Battery Replacement: 手順 3、 1の画像 1
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
終わりに
9 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Carrie Cutler
メンバー登録日: 09/28/16
500 ポイント
2のガイドは作成済み
チーム
Eastern Washington University, Team 2-6, Mathisen Fall 2016 Eastern Washington University, Team 2-6, Mathisen Fall 2016人のメンバー
EWU-MATHISEN-F16S2G6
4 メンバー
5のガイドは作成済み
4 件のコメント
where can you get a replacement battery
tedstorm - 返信
I have searched far and wide and cannot find a source for a replacement battery. Has anyone had any luck finding a replacement battery?
Edward Swar - 返信
Google ‘srs-x5 replacement battery’. That’s what I did, and found two different places in the US. I just ordered this one for $28, free shipping:
https://www.smavtronics.com/2600mah-lis2...
They have a higher capacity (3400mAh) for $35 , but I opted for the cheaper one since it was significantly higher capacity than the very adequate original (1800mAh). There also seems to be several retailers in other parts of the world. Thanks to Carrie for posting this, I was just about to replace the whole darn speaker, which still sounds as good as new!
pastabatman - 返信
My speaker would not power on at all (no lights). Reset button and pwr/- did not help. Seemed odd that the battery was dead as I hardly ever used it on battery. after unplugging everything, then plugging it back in with the battery unplugged, it came on. So perhaps the electronics (capacitor?) needed a draining reset to clear some strange state? …and that was not happening as long as a charged battery was plugged in. I had actually unscrewed/unplugged the speakers before realizing it was working again. Put it all back together and it works fine.
Mike Broderick - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 14
過去 30 日: 53
今までの合計 4,305
