メインコンテンツにスキップ
Sony SRS-X3 Speakers Replacement
必要な工具と部品
  1. Sony SRS-X3 Speakers Replacement, Speakers: 手順 1、 1の画像 1
    • Remove the rubber feet on the bottom of the device.
  2. Sony SRS-X3 Speakers Replacement: 手順 2、 1の画像 1
    • Remove the 6 silver screws with a Phillips #1 screwdriver.
    • Remove the bottom plastic cover of speaker.
  3. Sony SRS-X3 Speakers Replacement: 手順 3、 1の画像 1
    • Remove the two screws holding the battery pack with the Phillips #1 screwdriver.
    • Remove the battery back with a spudger.
  4. Sony SRS-X3 Speakers Replacement: 手順 4、 1の画像 1
    • Remove the three screws using a Phillips #1 screwdriver.
    • Remove the green circuit board and the battery pack.
    • The battery pack and green circuit board will still be connected to the speaker by a ribbon wire.
  5. Sony SRS-X3 Speakers Replacement: 手順 5、 2の画像 1 Sony SRS-X3 Speakers Replacement: 手順 5、 2の画像 2
    • Pop off the front speaker face (dark grey with little holes) by pushing out 3 tabs where screws were previously located and sticking the spudger in the crack where grey speaker face meets the outer shell.
    • You may really have to pry on this part; it is not easy to remove and will pop out when released.
  6. Sony SRS-X3 Speakers Replacement: 手順 6、 1の画像 1
    • Remove the eight black screws with a Phillips #1 screwdriver.
  7. Sony SRS-X3 Speakers Replacement: 手順 7、 2の画像 1 Sony SRS-X3 Speakers Replacement: 手順 7、 2の画像 2
    • Remove the front face by prying the two black tabs using a spudger.
    • This face is glued in and may need some elbow grease to remove. Don't worry about breaking anything, as it is all connected.
  8. Sony SRS-X3 Speakers Replacement: 手順 8、 2の画像 1 Sony SRS-X3 Speakers Replacement: 手順 8、 2の画像 2
    • Remove the speaker wires from each speaker (2 wires per speaker) and take the speakers out of the device.
    • The speaker wire connectors are made to connect very snug, so they should be hard to remove. Give it a good tug and they should pop off the male end.
    • Remove the speakers from the device.
終わりに
3 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Andrew Troyer
メンバー登録日: 01/17/17
312 ポイント
2のガイドは作成済み
チーム
Western Carolina University, Team 1-4, Virtue Spring 2017 Western Carolina University, Team 1-4, Virtue Spring 2017人のメンバー
WCU-VIRTUE-S17S1G4
4 メンバー
5のガイドは作成済み
4 件のコメント
Where would I get the new speakers from tho? Thanks a lot
Ruben Götz - 返信
Where I can buy one speaker as a spare part?
Karim Karimov - 返信
I would also like to know where I can get a replacement speaker
Aaron Todd - 返信
This SRS X3 cannot be used with the dc in 5v plugged, how can i do to make it work continuously with the charge cable? It have to be hacked? thanks
carlos cesar quan - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 2,511
