メインコンテンツにスキップ
Sony SRS-X3 Battery Charging Port Replacement
必要な工具と部品
  1. Sony SRS-X3 Battery Charging Port Replacement, Battery Charging Port: 手順 1、 1の画像 1
    • Remove the 6 10mm Philips head screws shown, using a PH1 screwdriver
  2. Sony SRS-X3 Battery Charging Port Replacement: 手順 2、 1の画像 1
    • Remove the 5 8mm Philips head screws shown. These are holding the battery and the green circuit board in.
  3. Sony SRS-X3 Battery Charging Port Replacement: 手順 3、 1の画像 1
    • Lift the battery pack and circuit board out of the housing and locate the wires and ribbon connector shown in the figure.
  4. Sony SRS-X3 Battery Charging Port Replacement: 手順 4、 2の画像 1 Sony SRS-X3 Battery Charging Port Replacement: 手順 4、 2の画像 2
    • Remove the ribbon connector and the connector from the battery pack (Note: These connectors are not easy to remove. Force may be necessary but the connectors are durable)
    • After the connections are remove you are free to replace the circuit board.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
bradley
メンバー登録日: 01/17/17
233 ポイント
1ガイドが承認済み
チーム
Western Carolina University, Team 1-4, Virtue Spring 2017 Western Carolina University, Team 1-4, Virtue Spring 2017人のメンバー
WCU-VIRTUE-S17S1G4
4 メンバー
5のガイドは作成済み
11 件のコメント
Bradley, this is a SONY 40BKB537U-CNF2G board….where can I get one? The mini charge port is bad on mine and v difficult to replace.
Thanks
michael ruse - 返信
Where can I buy the whole circuit board to replace the Charging port
Sony Mini speaker SRS - X3
40BKB537U - CNF2G
charging port
Morgan -
Where can I buy circuit board To replace charging port Sony Mini speaker SRS - X3
40BKB537U-CNF2G
Morgan -
Hi Michael, did you find a replacement board? I need to replace mine as well.
Julie Miller -
I have all the part of this speaker. Email me to negotiate! Kennyportillo99@gmail.com
kennycontreras44 -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 29
今までの合計 6,663
