メインコンテンツにスキップ
Sony SLT-A57 LCD Screen Replacement
必要な工具と部品
  1. Sony SLT-A57 LCD Screen Replacement, Remove the Battery: 手順 1、 1の画像 1
    • Remove the battery from the bottom of the camera.
  2. Sony SLT-A57 LCD Screen Replacement, Pry open the LCD screen: 手順 2、 2の画像 1 Sony SLT-A57 LCD Screen Replacement, Pry open the LCD screen: 手順 2、 2の画像 2
    • Delicately pry open the LCD screen from the plastic frame starting with the top edge of the screen (the top edge is on the left side of the camera when holding it). Pull open the bottom side of the screen after the top to avoid damaging the yellow flex cables located near the bottom edge.
    • When removing the broken screen be careful not to damage the thin adhesive strip that holds the display to the frame, as you will need to transfer this strip to the new screen.
    • Gently unplug the two small yellow flex cables from the bottom edge of the printed circuit board.
  3. Sony SLT-A57 LCD Screen Replacement, Transfer printed circuit board to new display: 手順 3、 1の画像 1
    • Carefully remove the thin adhesive strip that surrounds the old display and transfer it to the new one.
    • Unplug the wide yellow flex cable from the printed circuit board.
    • Gently peel the circuit board from the old display. Avoid touching the sticky surface.
    • Plug the wide yellow flex cable into the new display. Do not stick the circuit board down yet.
    • Tilt the flex cable and circuit board away from the display, then reattach the two small flex cables that come from the plastic frame.
  4. Sony SLT-A57 LCD Screen Replacement, Put the LCD Screen back in the camera: 手順 4、 1の画像 1
    • While being careful not to unplug the flex cables, gently press the circuit board to the back of the new display.
    • Delicately place the replacement screen onto the camera with the screen facing outwards.
    • Rub carefully but firmly all around the edge of the new display to ensure that the adhesive strip firmly holds the screen to the frame.
終わりに
5 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
AJ Draper
メンバー登録日: 01/21/15
437 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team 6-7, Brown Winter 2015 USF Tampa, Team 6-7, Brown Winter 2015人のメンバー
USFT-BROWN-W15S6G7
3 メンバー
8のガイドは作成済み
2 件のコメント
something is not right... it doesnt power up the screen I replaced....
eddie - 返信
finally got it work! make sure the bottom metal piece contact with the power side if you know what I mean.
eddie - 返信
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 28
今までの合計 4,930
