はじめに
When replacing the viewfinder, there are two separate components to detach. First, the eyepiece sensor needs to be removed before the viewfinder can be detached and replaced. The viewfinder will pop out from its slot by using your fingers to wiggle the part around.
必要な工具と部品
Unscrew the four 4.0 mm Phillips #00 screws with a on the base of the camera below the the scheme that separates the front and back panels.
Unscrew the 5.0 mm Phillips #00 screw on the bottom right of the camera.
Unscrew the two 4.0 mm Phillips #00 screw at the top of the camera by the eyepiece.
Unscrew the 5.0 mm Phillips #00 screw of the dial below the other two screws.
Once all the screws are removed, carefully use your hands to detach the back panel from the camera. Working around the edges can help as well.
Remove the four 3.0 mm Phillips #00 screws.
Remove the 5.0 mm Phillips #00 screw.
2 の人々がこのガイドを完成させました。
