はじめに
This article is devoted to replacement of e-Ink screen on your Sony Reader Wi-Fi PRS-T3. The main difficulty is to remove old double-sided tape by which screen holds on main body.
ED060XC5(LF)C1 screen have been used as a new part.
必要な工具と部品
Detach the back cover from the e-reader
Remove the black sticker, uncovering three additional screws. The sticker comes loose quite easy.
Unscrew all 10 screws (length 3.2mm).
Now take a spudger, and start opening the case at the top. There are four retaining clips at each side.
Unscrew these 5 screws (length 4.3mm) . They hold the front bezel (white or black part of the main body).
There are other screws that hold the motherboard (10×, 1.8mm) to the grey back plate. You do not need to remove them, unless you want to remove the electronics board (for example to prevent damage when cleaning the back plate in a later step).
Take a new screen. Apply double sided tape on back side.
Remove protective film from the screen
Put the screen into the black frame. Upper side of the screen should touch upper side of the frame.
Carefully join the screen in a black frame with the metal plate.
Continue assembling in a reverse order
8 の人々がこのガイドを完成させました。
20 件のコメント
This an incredibly useful guide. I have the new screen, but I have asked and have not gotten an answer about what double-sided tape is used to attach the new screen to the body. Could someone supply this information pleasae.
You may use any double-sided tape you'll find in a shop. I used a 0.5 mm tape or thinner. I found it in a Stationary shop.
mrdkonst -
Is the ED060XC5(LF)C1 screen, the same quality and matte as the original one? I don't trust asian sellers so much, but the only one that I found on internet is this one.
In my case it has the same quality. I bought it on Aliexpress also.
mrdkonst -
After installing replacement screen the touch functionallity does not work, screen itself seems to work but you cannot make any touch selections, does anyone has an idea?
