この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
If the power button on the device is faulty or not working then this guide will show the reader how to replace it.
必要な工具と部品
Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
Once the back cover has been removed locate the battery in the bottom right corner of the device.
Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
もう少しです!
終わりに
