メインコンテンツにスキップ
Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement
必要な工具と部品
  1. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: 手順 1、 1の画像 1
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 手順 2、 2の画像 1 Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 手順 2、 2の画像 2
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 手順 3、 1の画像 1
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 手順 4、 1の画像 1
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 手順 5、 1の画像 1
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement, Belt for the Tape Motor: 手順 6、 1の画像 1
    • Locate the motor of the radio on the underside of the top of the radio.
  7. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 手順 7、 1の画像 1
    • Unscrew the screw holding the motor to the top of the radio.
  8. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 手順 8、 1の画像 1
    • Lift up the motor.
    • Don't lift too high because the motor stand will break.
  9. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 手順 9、 1の画像 1
    • Unhook the larger band from under the motor and remove it.
  10. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 手順 10、 1の画像 1
    • Replace the band by hooking it beneath the motor.
  11. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: 手順 11、 1の画像 1
    • Push the motor back down and screw it into place.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Ian Nussman
メンバー登録日: 10/25/13
959 ポイント
6のガイドは作成済み
チーム
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013人のメンバー
UMASSD-GULBRANDSEN-F13S2G5
2 メンバー
6のガイドは作成済み
コメント 1 件
I'm worried about removing wires. How do you put them back? Doesn't that take some kind of special equipment/glue?
Carolyn Farley - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 45
今までの合計 5,089
