はじめに
This guide will teach you how to replace your motherboard in your Sony device.
必要な工具と部品
Use a Phillips #00 screwdriver to remove the four (4) screws on the back of the device.
If the screws strips or is previously stripped, refer to the stripped screw repair guide.
Unscrew the 3 (three) screws holding the bracket in place.
Then remove the bracket by prying one end up.
ある他の人がこのガイドを完成しました。
コメント 1 件
Hello
Thank you for your tutorial.
My question is about the rubber cap of the push button
Can it be changed? Spare part ?
Regards
