メインコンテンツにスキップ
Sony Pulse Elite Edition Headband Replacement
必要な工具と部品
  1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: 手順 1、 2の画像 1 Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: 手順 1、 2の画像 2
    • Remove the two 5mm Phillips #00 screws from each side of the headband connected to the metal track.
  2. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: 手順 2、 2の画像 1 Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: 手順 2、 2の画像 2
    • After removing the screws, push the small plastic protector on one of the sides towards the speaker closest to it.
    • After the protector has slid out of its slot, pull it away from the bar until it pops off the track.
    • Repeat this process for small plastic protector on the other side.
  3. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: 手順 3、 3の画像 1 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: 手順 3、 3の画像 2 Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: 手順 3、 3の画像 3
    • Using your thumb, slide the cushion on one of the two adjusting rails toward the closest speaker.
    • Once enough of the cushion has separated from the rail, pull the rest of it off.
    • Repeat the process for the other rail.
  4. Sony Pulse Elite Edition Headband Replacement, Slide Headband Off Rails: 手順 4、 1の画像 1
    • Gently pull the headband away from one of the speaker component groups, as if expanding it. Continue pulling until it is completely off the track.
    • Remove the white and red wires from inside the headband.
    • Be sure to keep the two speakers close together since they are still linked via the speaker wires.
    • Repeat this process for the other side.
    bro how can i buy pulse 3d headband?
    vahid najafi - 返信
終わりに
3 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Chris Echter
メンバー登録日: 01/29/15
865 ポイント
4のガイドは作成済み
チーム
Clemson, Team 14-2, Shirley Spring 2015 Clemson, Team 14-2, Shirley Spring 2015人のメンバー
CLEM-SHIRLEY-S15S14G2
5 メンバー
12のガイドは作成済み
コメント 1 件
have any experience with the sony gold headset, i got two of them that broke in the same spot, right at the hinge
Rich Gallagher - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 13
過去 30 日: 67
今までの合計 5,733
