メインコンテンツにスキップ
Fix Your Stuff
Right to Repair
Parts & Tools
はじめに
Prerequisite guide of earpiece deconstruction. Necessary for most part replacements.
パーツ
パーツは指定されていません。
  1. Locate the side designation on the headband-earpiece junction.
    • Locate the side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
  2. Gently pull around the perimeter of the ear cushion until it comes off. Gently pull around the perimeter of the ear cushion until it comes off.
    • Gently pull around the perimeter of the ear cushion until it comes off.
  3. Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup. Gently pull the outer ear rim off of the headset assembly.
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
  4. Using tweezers, gently pry the red and black speaker wires from the attached socket.
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
終わりに
Chris Echter
メンバー登録日: 2015年01月29日
853 ポイント
4のガイドは作成済み
チーム
Clemson, Team 14-2, Shirley Spring 2015 Clemson, Team 14-2, Shirley Spring 2015人のメンバー
CLEM-SHIRLEY-S15S14G2
5 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 102
